[HOU-1461] IPR refreshes too often. It should only refresh when the change effects the pixels.
  • [HOU-1461] IPR refreshes too often. It should only refresh when the change effects the pixels.
    Hi guys, just reporting that the IRP refreshes way too often. It should only refresh when the change effects the pixels.
    For example, renaming a node should not cause a refresh but changing the color should.
    Also, when I use the region render with IPR there is a bug. I use render region then stop the IPR then start the IPR, it doesnt use the render region.
      Hello stevejjd , I've reported first issue, about IPR restart on name change, but couldn't reproduce second one. What are your OS, Houdini and V-Ray build numbers? Or if you can send me a scene where region ignore issue appear.
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
        Houdini 17.5.360
        Windows 10
        VFH [Info] * Build number:6048 hash:507ddaf from 13 Dec 2019 04:16
        This happens on any scene including ones that have not been saved.
          Thanks stevejjd , I've reproduced it only with new scene and only after the first render region selection. HOU-1465 is the issue number in our system.
          www.chaosgroup.com
